1973 starcraft ss restore in progress
MikeSchinlaub
Ensign
Screw a sheet of aluminum or diamond plate on the bottom of the floor where you will have the pedestal seats. That's what every aluminum boat I've done a floor in has. I think it's too keep the seats from pulling out of the wood as it eventually rots.
crankbait cowboy
Looking for a bit more advice
power?
What do you all feel as far as power (hp) for this out fit?
is 90 sufficent or should I be thinking 115 or so?
thanks in advance
BWR1953
power?
thanks in advance
I learned (the hard way) to just install the max rated horsepower for the boat. That's what I'm doing with my current project.
Yes, it's possible to go lower, but at a minimum, recommendations are to use no less than 75% of max rating.
Sometimes less works for awhile in specific circumstances, but it's been my experience that more is better. YMMV. :cool:
Watermann
power?
thanks in advance
My 18' SS now has a 115 Merc on it, I think that's the sweet spot for an 18'r. Not a heavy gas hungry V6 and will push into the 40's at WOT.
UQTdIVqyAiaEIID8SRYAAAAAAAaCcE1OZNCei5I
crankbait cowboy
Getting closer to wrapping up ( if ya don’t need power) the story on the back bench is basically planning as I go. I think it worked out and will try show it in picks.
crankbait cowboy
3 screws hold back (black) 2 screws hold seat base and seat falls into place for easy removal, it got abit heavier than I had initially planned, but I’ll have to see when it hits h20
Reserector_
Chief Petty Officer" & 2021 Splash of the Year Win
2 x 4s are typically a bit much for anything but building construction. Each piece seems light, but man does it add up quick.
1 x (?) and plywood are better for what you are building. It forces you to use pocket screw joints or small blocks in corners, but I feel that the extra work is worth it in the end.
crankbait cowboy
I did get the steering cable mounted and steering wheel not bolted on yet ( a gift from my kids) until I get motor
Watermann
Yeah aluminum stock is difficult to work with and very expensive, I used it when building support structure for my raised casting deck framing.
DWbaseball
This is looking really nice and coming together quick. Keep it going this SS will be getting wet all summer!
I like the bench seat boats alot. Do you have any issues with reach to the stern cleats with the bench plus splashwell taking up space?
crankbait cowboy
Too early to tell on reach to cleats, haven’t splashed yet, but it looks doable
Watermann
2000 125 merc 2 stroke
Man I love my 4cyl Merc. The age is a factor for maintenance when I got mine the fuel system needed cleaned, new lines, a link n sync, full water pump kit, shift shaft seal, spark plugs and I replaced the water jacket gasket. Recently I replaced the starter and got a 900 cca starting battery, starts super easy.
crankbait cowboy
Drilling for motor bolt holes is really just math :whistle: and then re checking, and good knowledge gleaned from the interweb
