Moody Blue
- May 24, 2004
- 3,136
Re: 1973 merury 850 will not idle
Let the motor sit overnight and then remove the drain plug slowly. IF there is water in there, it will drain out first follwed by oil. If you don't see any water then you are good to go.
IF you had noticeable water after running for just 15 minutes on muffs, then I would guess that the lower waterpump/driveshaft seals and/or possibly the shift shaft seals are leaking. There are only 5 places water can enter the gearcase. 1) drain plug 2) vent plug 3) prop shaft seals 4) lower driveshaft (waterpump) seals 5) shift shaft bushing/seal. Since the gearcase is not underwater then you can rule out the "external" sources of leaks.
No predicting how much water is "safe" from freezing in the lower unit. If there is any concern, drain the oil.
new lower unit oil turned milky after running for about 15 minutes and it had time to settle after running that I am pretty sure that it was not foam. How much water can be in it before I have to worry about it freezing and busting something? This should be under another thread but figured it would be an easy one. Boat is in the garage but not heated and very little insulation. I guess I can run it a little in neutral with milky oil a couple of times. I have got everything that says seal or o-ring in lower unit on order. I have already replaced impeller and all gaskets and upper housing.
