bigsidster
Thread starter- Joined
- Sep 18, 2007
- 11
I have a 1973 Mercury 500-50 hp-2 stroke---4 cylinder outboard.I have a Power Fist Electronic LED Tachometer 0 to 8000 rpm.It is a TRISCO brand.It is a 12VDC and has a setting button to set it for 4,6 or 8 cylinder.Has 5 wires coming out of it.BLACK is ground to -negative battery terminal,RED is tach power wireto ignition ON (run) position.ORANGE is memory LED and goes to battery +positive.WHITE is night light and goes to light switch.GREEN is the Tachometer signal wire and connects to signal source.
2 questions?
Can I install this tach and use the "4 cylinder setting" and get a correct reading?
If I can,where do I connect the GREEN tach source wire?
Thanks for any help you can give me.
2 questions?
