michael0972
Thread starter- Joined
- Mar 24, 2007
- 2
8)
I just purchased an old pontoon that I am planning on using to scuba dive off of. I bought it from a private individual and when we took it out for a spin I noticed there was not water comming out the pea streem. I asked the guy about it and he said it worked the last time he had it on the water 3 years ago. The boat did not seem to get hot while we ran it, so I bought it.
I replaced the water pump today and took it to the lake to test it out. There is still no water at the pea stream. I ran a piece of wire up the hole as far as it would go, which was probably 18 inches, it did not seem to be plugged at all. I took it out about 100 yeards from the dock thinking that I needed to rev the motor up a bit more to see if more pressure would force it out. I then noticed smoke or steam starting comming out for the pea stream whole, but no water. The motor then reved down on its own and then quit. We drifted to shore and I wenched it on the trailer.
Any ideas what is going on? Did I overheat it and blow up my motor? The motor was very hot when it quit. But it probably only ran for a total of 5 minutes.
