1973 Merc 500 Steering
Tanksmydog
I have a 1973 Merc 500 that is tough to turn side to side(steer.) Is there a grease fitting that will make it easier to turn? I have been unable to find one on the motor or in the SELOC manual.:confused:
Re: 1973 Merc 500 Steering
The OB will be hard to swivel for one or two reasons. Either the steering cable is hard to move or the OB itself is hard to move, or both. First disconnect the OB from the steering cable. If the OB is hard to turn, the problem is usually the upper bushing on the swivel shaft. There should be a grease fitting on the midsection. See if you can pump grease out the upper and lower bushings. if not, you will need to use some heat on the upper bushing to make the old grease come out. Refill with fresh grease.
if the cable is hard to turn, you need to find out why. Disconnect the large nut where the cable meets the tilt tube of the OB. Now if the steering wheel turns freely, the cable is binding in the tilt tube. Use some penetrating oil and heat to get it out of the tilt tube. Dont hammer the end or it will mushroom. After it is out, clean and gease it well and reinstall.
Tanksmydog
Thank you Chris that helps alot....but would you happen to have a pic or know where I could get one...even in the manual....I have the Seloc Manual online. Thank you for the help either way.
