1973 Johnson 65HP Starter Question?
CaptainT16
Good Afternoon, was out at the lake today and everything ran great, and then later in the morning, I tried starting the motor and my battery was getting weak, so I switched batteries. The motor fired up and died and now once I try to start the motor, all you can hear is a clicking sound everytime you turn the key? I thought it might be the battery, so I went home and put jumper cables on the battery and tried cranking it just to see if it would crank over with no luck. I'm guessing that the starter has probably gone out? The engine model number is 65ESL-73R. The number that shows on my current starter is MCD4106A. I've been looking on line trying to locate a starter, but have had no luck? Can someone please let me know possibly the starter number I would need, or if anyone even thinks it's something other then the starter. My father did not think it has ever been replaced. Any help would be greatly appreciated. Thank you!
