The 385532 original shock for your engine is still available from Bombardier, as a "special order" part. Yes, it's just under $200. You might be better off finding a good used transom bracket from another 73 and swapping them out. That part number may also have been used for a number of model years. You can check out the part usage on the factory exploded parts diagram website: epc.brp.com. If you ever wanted to add a complete power trim/tilt unit to that engine, you would not need to replace the shocks-they are not required. I'm a fan of the power trim on that engine, tho it's been NLA for over 20 years. You'd be looking for a junk engine 1973-1977 V4 with a good trim system on it. Might be just as cheap and a better solution.
