1973 Evinrude 25hp
gwg
Which cylinder is considered #1 and #2 ? Bottom or top?
gwg
What is the proper throttle advance linkage adjustment for this motor 25302A?
AlTn
1 = top...throttle advance is set so that when the throttle valve <butterfly> is just beginning to open, the carb linkage roller is centered on the raised mark on the timing cam...when in forward gear and the throttle is fully advanced the roller should be on the highest point of the timing cam
