crawler691
Thread starter- Joined
- Apr 24, 2010
- 9
Was it common in the 70's for the manufacture to place fiberglass bondo over the rivets? I ask this because i recently purchased a 73 crestliner (hull number CRL45814M73I). I am replacing the floor the previous owner removed and noticed this loose rubberish material. so i preceded to scrap off the loose material and while i was scraping i scraped up a strips of fiberglass bondo (I will post pics). the strips where extremely easy to pull up which makes me think that the fiberglass was not attached to the hull. when i purchased the boat i was told that the boat leaked a little (2-3 gal/5-6 hours) and that it was expected to leak somewhat because if its age. since the fiberglass was easy to remove I'm thinking it was doing little if anything to stop the rivets from leaking. I am guessing these strips are on all the rivets along the bottom hull. I just find it weird that there are fiberglass bondo strips on the aluminum hull. should i worry about the removal of those strips?
on to the pictures
the first pic shows the rubberish material in between where the fiberglass strips were.
the next two show one of the strips and the hull\
this next one just shows the fiberglass strip, nothing special.
thanks for any input/ideas/insight.
on to the pictures
