1973 Chrysler Fin & Fun Rebuild
esimmons92
Re: 1973 Chrysler Fin & Fun Rebuild
Hey guys it has been quite a while since i have had a chance to get an update on here.
Since last time
I posted, finally determined my issue was all because of some old MEKP.
As of yesterday, I have bought 5 more gallons of resin(brings me up to 15)
Over the last few months i fished glassing my stringers and tabbed in the rest of my transom.
I also cut and glassed my bulk heads which were surprisingly harder than expected as you can see in this picture, i left a whole on each side of my hull for water to drain to the bilge .when the boat was made, this area in between the 2 stringers had no foam in them, so i plan to leave it empty for drainage.
I also cut the deck out. and I was able to make do with only 2 sheets of PLY !!!! thanks to some new found dry wall skills i was able to "piece together " part of the deck I decided that whis would be fine because it lands on bulk heads and it is just for storage under the seats.
as most of you probably remember i had the plan to glue pink foam together for my flotation and after much conversation with you all, you suggested me using pink foam to just take up space so i can use less pour in foam.
so after i glassed the bottom of the deck, i cut 6 inch strips of pink foam and glued it too the bottom side of the deck(only on the outside of the stringers). just to take up just enough room so i will have enough pour in foam. (i bought the 8 cubic ft of 2 lb foam from us composites.)
here is a picture of the deck as i was putting it down yesterday.
Woodonglass
Honorary Supreme Mariner
Good to have you back on the forum and making progress! Deck looks Good! Steady as she goes!!!
GT1000000
Welcome back!
Glad to hear you figured out the resin problem...
Progress is looking amazing, great job!
esimmons92
1 quick question.
When drilling holes in the transom for the motor and ladder, do I have to resin the inside of the holes or can I just put a lot of 5200 on it?
More updates coming soon
