damexican67
Thread starter- Joined
- Sep 20, 2007
- 11
Hey guys how are you all doing? A friend that I am helping out with his motor has discovered that the #3 cyl had only 5lbs of pressure.The #1 had 100-105lbs, the #2 had 110-115lbs, the #4 had 118-120lbs. As to why I removed the head to see if I could spot a problem and I noticed that the #3 piston was chipped and scored. Now my question is can I have some one walk me thru the steps for replacing the piston/arm. Or is it a bad idea for me to attempt this task?
