1973 65HP Triumph Exhaust Manifold Question
05220713
By chance does anyone have the official torque value for the 17+ bolts on the exhaust manifold to engine block for a 1973 65HP 3 cylinder Triumph?
F_R
They are 1/4" bolts, right? 60-80 inch pounds.
I hope you closely inspected the inner plate. They had a real bad habit of warping in the area of the exhaust ports, allowing water to enter the ports and destroying the whole powerhead.
Yes, 1/4” Bolt’s. Actually ordered some refurbished plates. Along with the new gaskets would you recommend a gasket sealer like permatex red high heat or just reinstall with new gaskets only? Thanks for your help.
F_R
OEM manual says to use OMC (BRP) gasket sealant. Not saying not to use your stuff, I just don't have any experience with it.
05220713
Ok, that works. I will look into the OMC (BRP) gasket sealant. Thanks Again
