1973 135hp Evinrude Help
Ed in North Texas
Rebuilt '73 135 hp Evinrude. Converted to run on unleaded fuel. New control box. 120 to 124 psi on all 4. Started the year w/ #3 not firing. Mechanic re-timed and adjusted carbs and all 4 are firing and speed on the Graph is right at WOT for this boat. Problem is after sitting and fishing for a while I can not accelerate. After a couple of minutes of inching the throttle up, she will finally take off. Does not do this when first used, and will not do it if I shut it down, then re-start after only a minute or so. A mechanic says it wouldn't be the fuel pump, or it would do it all the time. Anyone have any bright ideas?
