Fowlplayoutfitters
Thread starter- Joined
- Aug 9, 2017
- 1
I am the new owner of a 1973 135hp. I was told when I purchased it that it does on the water due to a bad coil. I checked my spark and indeed did have a cylinder not firing. I changed the coil out with a donor I had and was able to get it started. Took the boat out ran smooth without any kind of miss but had no mid or high range power. Turned the boat off and never would start up again. Now I'm showing another cylinder not firing while another appears to have weak spark. The rectifiers black wire is about to snap due to corrosion and I have green ooze dripping down from the stator. Are these my two problems?
