1973 135 ignition problems
Fowlplayoutfitters
I am the new owner of a 1973 135hp. I was told when I purchased it that it does on the water due to a bad coil. I checked my spark and indeed did have a cylinder not firing. I changed the coil out with a donor I had and was able to get it started. Took the boat out ran smooth without any kind of miss but had no mid or high range power. Turned the boat off and never would start up again. Now I'm showing another cylinder not firing while another appears to have weak spark. The rectifiers black wire is about to snap due to corrosion and I have green ooze dripping down from the stator. Are these my two problems?
interalian
The first thing you need to do is test compression. Post up your numbers first, then we can get to the other problems. Last thing you want to do is spend money before you know the foundation is solid.
Ooze from the stator could point to overheat which could also cause compression problems.
derek4325
Defiantly want to do the compression test as interalian just stated. Is the green ooze like gas foamy stuff? Hopefully someone else could back me up on this but that sounds like an upper crank shaft seal problem to me. And as far as the bad wire to your rectifier, that should not affect the motor running. That all has to do with charging. But once you have confirmed you have good compression, check for spark again when the engine is dead cold. A lot of times a coil will appear okay but then break down under the stress of running it. If you then have good spark then odds are you have coil issues in other cylinders. Try that first and see what happens. Before running it again make sure your cooling system is in check. If your stator is breaking down from the heat.
