1972 mercury 500 lower unit leak
archiezift
My 1972 mercury 500 (50HP) normally develops a milkyness to the oil every second year or so and i get it fixed at the shop, now I have all the tools and ability to take the leg off and do the work, does anybody know which seal normally leaks first, or is it a case of replacing them all?
1960 Starflite
Re: 1972 mercury 500 lower unit leak
Two seals, one in the bottom of the water pump (replace impeller while in there) and prop shaft seal. Could also be shift shaft seal. There is a drain hole visible on the outside of the lower unit for the shift shaft cavity, make sure it is open.
Moody Blue
The simplest and cheapest to repair are the sealing washers under the vent and drain plugs. It is recommended that they be changed and not reused once the plugs are removed.
I would start simple and go from there. What has the shop done in the past?
bgc
Ensign
We use this connected to a hose attached to the metal fill adapter to Pressure/Vacuum check lowers. Pressurize the lower and submerge in water to verify what seal is leaking. Several of my old Mercs leaked from corrosion on the drive shaft at the seal.
Faztbullet
As posted, its most likely the driveshaft is corroded/pitted at water pump seal area as these where mild carbon steel. These can be repaired with a speedi sleeve
If you have a 0.75" driveshaft (where the waterpump seals run) then the SKF Speedi Sleeve P/N is CR 99076, you will need 2 of them, as they are only 0.300" long. I used a bit of Mastinox under the sleeve to try and stop the corrosion.
archiezift
Thanks for everys help, bought a pressure test kit, made special tools, oil was milky when I drained it, replaced the propshaft seal & new oil, gave it a run and hey presto, no water in the oil
bgc
Ensign
Good news!, Hope it works out!
