1972 Johnson 9.5 blowing blue smoke
jon1234
Hi There<br />my 1972 Johnson 9.5HP is blowing a fair bit of blue smoke<br />what would cause this<br />compression is good <br /><br />Jon
Paul Moir
Re: 1972 Johnson 9.5 blowing blue smoke
Running rich would. How do your spark plug firing ends look/compare?<br /><br />Does the engine run worse when you pump the primer bulb?
jon1234
I have brand new spark plugs <br />they look a little black<br />the engine wants to die if you pump the primer bulb too much
Paul Moir
Ok, that would suggest that the needle in the needle & seat in the carburetor is leaking a bit, or the fuel pump is leaking. When all is well, pumping the primer will have not have an effect on the engine's running.<br /><br />To determine if the fuel pump is ok, unscrew it from the engine and pump the primer. If any gas comes out of the little hole on the back of it, then the diaphram is ruptured. I don't think this is the problem but it's easy enough to check. Usually when this is the problem one spark plug is tan and the other is black.<br /><br />So if it turns out to be the carburetor, pick up a service manual and a carb kit. If you want you can often borrow the service manual from the library. Get the carb kit from your local Johnson/Evinrude dealer because it comes with a new plastic modern fuel tolerant float to replace the troublesome cork one. The aftermarket kit sold online, etc, doesn't come with one. The dealer kit is only a couple bucks more anyway.
jon1234
thanks<br />i will give that a try and get back to you tomorrow
