colewhitmore41
Thread starter- Joined
- Aug 13, 2016
- 6
I have a 1972 Johnson 85 hp electric shift that I discovered had no spark. I then discovered after looking around that one of the two wires coming from under the flywheel that connects into the white and black striped wire coming out of the amplifier assembly is corroded all the way through. What part does this wire lead to under the flywheel and how do I replace it.
