1972 johnson 50hp tach
rookie456
I would like to add a tach onto my 72 johnson 50 hp electric start. It seems that there are a lot of tachs to choose from and they range in price. Can someone tell me if I need a certain type of tach for my engine?
eavega
Re: 1972 johnson 50hp tach
You need a tach with a 6P setting. Three basic connections in the back; +12V (purple wire), Ground, and the grey signal wire that should be in the remote control (might be taped up if the engine has never had a tach). There may be an additional connection if the tach you purchase is illuminated.
Rgds
Eric
boobie
That mtr would require 5 P position on the tach.
rookie456
I do not see 5 p or 6 p called out in any description of tachometers that I have looked at. Does anyone know if part # 0177103 will work for a 1972 johnson 50 hp model 50esl72?
phipps
Are you looking at automotive tachs? There is a difference and like everything else "marine" ours are more expensive.
