1972 Johnson 20 hp wont stay running
amvaneyk
Finally got it to crank but it wont stay running. It has alot of blue smoke coming from it and the only way I can run it is if i keep pulling the choke out just before it stalls and than pushing it back in. Any suggestions?
olenavygoat
Re: 1972 Johnson 20 hp wont stay running
Your fuel/oil mix should be 50:1, preferrably a synthetic since for some reason the conventional oil will produce more moke. Also check your plugs for corrosion and spark. I would also recommend running your adjustment screws in to a gentle seat, then back out 3/4 turn. You can fiddle with it from there. I'm hoping you don't have trash in your fuel, but that would be next. Do you have a simple in-line filter on your fuel line?
amvaneyk
Yes I have 50:1. Brand new gas tank and gas so there shouldn't be any trash in the lines.
