1972 johnson 100 hp water pump
b1eco1ol
quick question, how do you know that the engine is pumping water well with muffs, or in the water. is there a stream of water from the motor you'll see, or what. thanx
tashasdaddy
Re: 1972 johnson 100 hp water pump
droplets or mist out the exhaust relief ports. 1/2 way up the leg green arrow.
b1eco1ol
ok that will happen even with muffs? saw water out the prop didn't see that from the two holes up top. do you know where i can find a pump kit online for cheaper than 199.00 i think thats to high for a water pump kit.
Daviet
Go to top of the page and click on johnson parts, looks like a kit for your motor is about $50.00
