1972 Evinrude 9.5 hp fuel pump assembly
Evinrude Boater
Having problems pumping fuel up to the carburetor. Replaced the bulb and line connectors but it won't pump past the pump assembly. I took the pump off and opened it so I'm not certain I have the layers assembled properly. The parts diagram on Evinrude is no help. Does anyone have a detailed exploded parts diagram?
Also, when I pump the bulb it blows air into the gas tank and draws fuel but doesn't squirt out the pump into the carb fuel line. Any ideas?
Incidentally, I had problems last season where it started and ran for a minute then died and wouldn't start for another day or so. I thought it was sucking air on the fuel lines so I changed the connectors.
Well ----the check valve in the bulb should prevent air being pumped to the tank.----So the bulb arrow is pointing the wrong way .----Or the bulb is defective---Look for ----Leroysramblings-------Will have pictures of fuel pump
Evinrude Boater
Arrow pointed to motor. Two bulbs both bad? I've got the rebuild instructions and starting to study them. I don't like the instructions in bold upper case to make sure you know which way it came off the motor. Of course I disregarded that important detail.
Is it the wee square pump ?------There is an arrow on it somewhere with UP.-----You can study the gaskets / covers / diaphragms to see how they were together.------Still it could have been assembled wrong.
