Evinrude Boater
Thread starter- Joined
- Jul 6, 2004
- 1,148
Having problems pumping fuel up to the carburetor. Replaced the bulb and line connectors but it won't pump past the pump assembly. I took the pump off and opened it so I'm not certain I have the layers assembled properly. The parts diagram on Evinrude is no help. Does anyone have a detailed exploded parts diagram?
Also, when I pump the bulb it blows air into the gas tank and draws fuel but doesn't squirt out the pump into the carb fuel line. Any ideas?
Incidentally, I had problems last season where it started and ran for a minute then died and wouldn't start for another day or so. I thought it was sucking air on the fuel lines so I changed the connectors.
