edgexswitchback
Thread starter- Joined
- Jun 3, 2016
- 8
I'm hoping someone here is smarter than my outboard guy and me. He has been working on these since they were new and is stumped.
Symptoms: Will fire right up hot or cold. Will idle or run at low speeds all day. Try to go WOT and it will start to pick up but then slowly loses RPM's (but will never die). Can't get it to completely stall no matter how hard I try! Seems to be misfiring on a cylinder.
What's been done: New water pump. Good compression (120ish) on all 3. Fuel pump rebuilt. Good fuel lines. Checked for obstructions all the way from tank to carbs. Carbs are super clean. Floats set properly. New plugs and wires. New fuel in tank. No water or derbis. I did a siphon from the tank to the motor to make sure it wasn't pulling in air and to make sure it had good flow. Reeds look good (from what I can tell with the carbs removed). I don't know the resistance values for them but all 3 tested about the same.
Thanks in advance for any tips!!!
