1972 Evinrude 40 HP I just purchased. I need help please...
Huntleybill
I purchased a 1972 40 HP Model 40202E from a guy that says the motor ran last year. Upon getting the motor home, I cleaned the mouse nests out of it as it seems it has been sitting behind his garage for awhile. I put a battery on it just briefly to check/confirm the following:
The starter works and engages.
The motor does turn but seems to be stiff. ( I'm thinking that may be because it's been sitting??????)
There is spark at both cylinders.
Because it has been sitting, I didn't want to spin it over too long.
What I would like to know is what I need to do to check this engine out. What should I do to prep it to start. If you can guide me on what to watch out for etc. Any other recommendations would be very appreciated.
Thank you all.
Bill
Daviet
Re: 1972 Evinrude 40 HP I just purchased. I need help please...
Look in the "Top Secret File", there is a lot of information there including a section on awakening a sleeping outboard, it might ansewer a lot of questions for you.
Huntleybill
Thank you Daviet. What and where is a "top secret" file?
samo_ott
Yes, read the top secret stuff at the top of this forum. and put some oil/lube in the spark plug holes... BTW, they all *say* it ran last year!
Huntleybill
I didn't buy it either Steve, but I want to be careful and at least not really screw things up.
