1972 evinrude 115 blowing fuse.HELP!
valtis
Boat was sitting for tree years. I took it to the mechanic, he start the engine and said everything is working perfect. I took it on the water was running fine for about 15 minutes and then blow the fuse.Mechanic told me to replace ignition coils, I did replace them. Try in the backyard it was working fine. Took it on the water again and again the same thing: was running fine but after I shut the engine off and try to start backup it start blow fuse again. Mechanic don't event want to answer the phone no more so PLEASE HELP ME! Thanks
R.Johnson
Re: 1972 evinrude 115 blowing fuse.HELP!
If that engine still has what is called a clipper switch, remove from the system. In the OMC repair manual under trouble shooting guide as I recall, it will say, if engine blow's main fuse, and continues to blow fuse, replace clipper switch. That switch does not need to be in the system. If the pulse pak is being replaced, they advise removing this switch. Rapair will not honor the warranty on the pak if this switch is left in place.
