1972 65hp johnson outboard carb question
jhyams00
65esl-72s is model number wondering why there is a shift available on engine for choke adjustments my model can be on/off/manual what is reason. i have choke on throttle up front what should one in back be set to? any help would be appreciated
Daviet
Re: 1972 65hp johnson outboard carb question
If you have to hand crank the engine (dead battery), you will have to set the choke manually to on. When the engine starts you have to manually take the choke off. To use the automatic choke you should set the manual choke to the middle position (off). Have some one work the choke switch and watch the choke and see if it closes the choke plates in the carbs.
jhyams00
thats exactly what i needed to know thanks again
Daviet
You're welcome, any more questions just ask, lots of people here will help you out.
