1972 65hp Evinrude
blufire42
Hey guys, I'm fairly new to boat owning world. Just bought a 15' fiberglass boat with a 72 Evinrude back in early February. When I first bought it the guy told me that the top cylinder was not firing and it was due to a bad stator. He cranked it up for me real quick and it seemed to start fine and idle ok, so I bought it. A week later I took it on the water just for a test drive and the motor seemed to do ok, just wouldn't reach not accelerate past half way on the throttle. Tried easing it back a few times and trying again, still no luck. I take it back in and while at the dock I shut it off so I can go get my truck. I come back to try to start it again and it it won't even try to turn over. Well I pull it up to the trailer with a rope and take it home. I put the flush muffs on and go to crank it up and it does, so maybe the motor just got flooded or something.
Well the next week I decide to replace the stator and I get it on and it won't crank at all, the top cylinder still won't fire either. I back trace it with spark plug, coils, powerpack and after replacing all those I come to find out the timer base is broken. I just put that on yesterday after it came in the mail and after a few tries getting it cranked, she fires up. I am ecstatic that after 3 weeks of replacing parts and spending too much money that she finally cranks up again. So I get her finished up and take her down to the water and she seems to be idling ok in the water, I go to open her up real slowly and she still won'g go past half throttle...just sits at the same speed. I turn it off to test a new trolling motor I got, and the engine won't start up again just like it did the first time I was out. Well thankfully I had the trolling motor, I got her back on the trailer and back home.
Any ideas as to why it won't go past half throttle as far has rpms and speed, and why the motor won't start back up after I shut if off on the water and try cranking it back up?
flyingscott
Are you mixing the gas at 50-1 and is your motor overheating. If not you probably still have a cylinder not working as stator or base will usually not just shut down one cylinder. Find the cylinder that's not firing and switch the coil with a working one make and see if the problem follows the coil.
blufire42
Yes I am mixing 50:1, and the motor is not overheating that I can tell. I'll check the cylinders again, but I did just replace the top coil with a brand new one.
Thanks for the advice, I'll post back what I find
jimmbo
Have you checked to see if the carbs are opening fully at full throttle?
blufire42
No I have not yet...I know when it is sitting at idle, the bottom two closed, and the top carb is opened. I was just doing other research and are they ALL supposed to be closed at idle and then as you throttle up, they open to reach perfect horizontal at full throttle?
jimmbo
The carbs are supposed be all at the same angle, there are adjustable linkages to sync the carbs to each other. There is also a synchronized relationship between spark advance and carb opening. With these engines, the carbs open very little until the ignition timing is fully advanced, then the carbs open very rapidly
flyingscott
Get a manual if you don't think the carbs are right you will need to do a link and sync easy to do but will need the manual. You don't say anything about the fuel system when you take it out and it bogs pump the ball on the fuel line. This will determine if it is a fuel pump problem.
oldboat1
Your symptoms aren't quite the same, but you've had the flywheel off for repairs and may not have torqued it down sufficiently. As a result, the woodruff key may have sheared or partially sheared, flywheel position shifted, timing off. The current thread by hadaveha might be instructive (March 20th, with current updates). Johnson 55.
Use the method shown and described to check timing. If the timing is off, pull the flywheel and have a look. Given your prior ignition work, it might be a good idea to pull the flywheel anyway and check assemblies, wiring -- I find it usually makes sense to recheck recent repairs as a first step in troubleshooting.
blufire42
Thanks I'll be sure to do the timing check. I was looking at it tonight after work before it got dark, and it looked like the spark advance screw was too far out. It was not allowing the timer base to move much at all. So I shortened the screw and it ran a little better, but would still bog down a little after half throttle. I did the link and sync with the carbs and after that it seemed to rev up fine, but going to take it out to the river on Friday when I'm off work and test her out then.
