Hey guys, I'm fairly new to boat owning world. Just bought a 15' fiberglass boat with a 72 Evinrude back in early February. When I first bought it the guy told me that the top cylinder was not firing and it was due to a bad stator. He cranked it up for me real quick and it seemed to start fine and idle ok, so I bought it. A week later I took it on the water just for a test drive and the motor seemed to do ok, just wouldn't reach not accelerate past half way on the throttle. Tried easing it back a few times and trying again, still no luck. I take it back in and while at the dock I shut it off so I can go get my truck. I come back to try to start it again and it it won't even try to turn over. Well I pull it up to the trailer with a rope and take it home. I put the flush muffs on and go to crank it up and it does, so maybe the motor just got flooded or something.
Well the next week I decide to replace the stator and I get it on and it won't crank at all, the top cylinder still won't fire either. I back trace it with spark plug, coils, powerpack and after replacing all those I come to find out the timer base is broken. I just put that on yesterday after it came in the mail and after a few tries getting it cranked, she fires up. I am ecstatic that after 3 weeks of replacing parts and spending too much money that she finally cranks up again. So I get her finished up and take her down to the water and she seems to be idling ok in the water, I go to open her up real slowly and she still won'g go past half throttle...just sits at the same speed. I turn it off to test a new trolling motor I got, and the engine won't start up again just like it did the first time I was out. Well thankfully I had the trolling motor, I got her back on the trailer and back home.
Any ideas as to why it won't go past half throttle as far has rpms and speed, and why the motor won't start back up after I shut if off on the water and try cranking it back up?
