cajuncook1
Thread starter- Joined
- Sep 3, 2009
- 559
Hey guys, just fixed a 1972 2hp Johnson for a kicker and for the fun.
Problem: Can not maintain idle or running if I am not pulling the choke in or out or have the choke half way out. I tried adjusting the slow idle need but no go.
-the valve from the tank is wide open
-the screw cap on the tank is open (even took the cap off)
Information:
- clean the carburetor and installed a new kit ( the float is level)
- cleaned the tank and filter and fuel tap valve
- new fuel hose
- new impeller (water is coming out find and head temps no greater than 134 degrees
- new spark plug Champion J6c gapped at 0.30
- new points gapped at 0.20
- new condensor
- new coil and flushed with mounting boss
- great blue spark with tester at 1/4 inch. ( spark is strong enough to ignite a fart 3feet away)
- compression reading at 95lb with 3 pulls of the cord (single cylinder)
- new gear oil in the foot.
- gas mixed fresh 50:1
-slow idle needle is out at 1 1/2 counter clockwise (factory manual recommendation and needle is in good shape)
- fast idle needle is out 1/2 counter clockwise (factory manual recommendation and needle is in good shape)
I was going to do 2 things but wanted to check with you gentlemen to see if there is something else I am missing?
- revisit the mounted fuel tank and recheck for junk, clogged filter, and reclean the valve.
- get a new carburetor kit and reclean the carburetor.
Any suggestions would be welcome.
Thanks,
cajuncook1
Information:
- new fuel hose
- new condensor
Thanks,
cajuncook1
