Re: 1971 ss ?
some quick areas to check:
1. soft floors?
2. soft transom?
3. missing rivets, big dents, etc in hull?
4. does motor turn over? compression in cylinders? spark?
5. if you can run it in a trash can, look for water discharge from water pump. does it shift in and out of gear? steering work correctly?
6. TITLE for boat n trailer??
7. can trailer be pulled home as is or will it require tires/lighting work first?
8. how much equipment/repairs will it take to meet USCG requirements and those for your state? check your state DMV or whoever's site before you go look at it.
9. i see you're in GA. any evidence of salt water use?
10. do all boat lights & electrics work?
11. will your spouse divorce you if you buy it? will seller's spouse divorce him/her if he/she doesn't get rid of it?
lots of other stuff but this is some of the common stuff that will help determine how much of a project you're diving into, and some areas that can be used as negotiating points with seller. also think about what you want to use the boat for and evaluate it in terms of how it will do for those uses (you wouldn't want to use a flat-stern Jet Star for offshore fishing, or a 22' Islander for a small lake, etc). i'm assuming boat is 16'? if so, a 65hp will be great for fishing and general playboat, maybe a bit weak for pulling multiple skiers. i'd suggest you also skim some of the threads here on resto of similar model so you can see what others have run into and get some ideas on how they "should" look. do some homework on here and you can be a seriously educated buyer.
