QWXZAS12345
Thread starter- Joined
- Apr 29, 2002
- 14
I have just put a new engine on my boat (1971 mercury 650 w/ thunderbolt ignition) I rebuilt the carbs on this engine before installing.... my question is about the 2 main cables that connect the throttle and gas lever from the ignition. I was able to adjust the main throttle so that the gears matchup (forward, nuetral, and reverse) I am not sure where the starting position on the gas lever should be... there is somewhat of a locking position in accordance with the linkage off the distributor bascially right in the middle and I was guessing this would be where you might adjust it to.. but I wanted to make sure this position is correct before I move on to adjusting the idle speed on the carbs... the engine runs fine but hesitates a little before accelerating from neutral...any tips on this would be a great help...<br /><br />thanks again guys,<br />boaty boat
