Moody Blue
Thread starter- Joined
- May 24, 2004
- 3,136
A bit of background info first.
Have begun the task of refurbishing my 1971 Merc 800 motor. Problem began with cronic poor idle performance and stalling when put into gear. I also found signs of water intrusion on #4 cyl - rusted plug and steam cleaned piston head.
After pulling the powerhead I discovered that the lower crank bearing was shot (ball retainer had completely been destroyed). After pulling the lower retainer cap I found the one seal badly worn. Next I pulled the top retainer cap and found that the upper crank bearing was also shot. The ball retainer came out in about 8 pieces. Proceeded to split the crankcase and do a further inspection. Removed the rod caps and center main bearing and found all crankshaft bearing journals in pristine condition. No signs of rust inside the crankcase.
The center bearing race had some minor wear marks and I posted an earlier thread on that issue here
http://forums.iboats.com/mercury-ma...-800-center-main-bearing-question-589483.html
Noticed some minor scoring on the #4 cyl walls so I pulled the #4 piston. There was significant pitting/errosion on the piston top and the upper ring was seized in its groove. It's not reusable. All other cyls look perfect.
The rod caps/bearings/races all look great.
My plan is to replace what NEEDS to be replaced, clean it up as best I can and put it back together. I know at this point I need new upper and lower crank bearings, new upper and lower crank seals and a lower crankshaft wear sleeve. I also plan on replacing the bleed restrictors that were missing in the intake transfer ports.
Here are my questions to start. I'm sure there will be many to follow.
1) Can I take a piston/rod/bearings from a donor motor to replace the damaged #4 piston or must they be NEW?
2) Can I swap the piston/rod/bearings from one cyl to another or MUST they stay in their original cyl?
3) What may have caused the damage to the #4 piston? I want to prevent that from happening again.
4) Is it acceptable/recommended to replace the bearings (rod cap, center main, wrist pin) or resuse them if in good condition?
Thanks for your time and looking forward to your replies.
