1971 johnson 9.5 wont Run. Help
MikMac
Hello all. I can use your help.
Im a newbie with some decent mechanical skills, but i,m dumbfounded with this 1971 Johnson 9.5.
Thanks to all your posts. I have got this far. now im stumped.
At first i wasnt getting proper spark from 1 plug. I tore the entire top end apart and cleaned everything up including the points.
I checked both the primary and secondary windings on the coils with Ohm meter. Both checked out. I then cut 1/4" from end of spark plug wire and reinstalled on both coils, because they looked a little corroded. Then set the points to exactly .020".
First Question: I read many posts about the timing. Is it true that as long as i have everything put together right, and the points are set at .020". that is the timing? Because i have both points opening and closing at .020" and closing completely.
I put the system back together then tested the spark. Spark is excellent. again , traced spark plug wires back to coils. they are on the right plugs. Good spark.
Cleaned the carb, and inspected all orifices. I took out the main high speed. cleaned everything with carb cleaner. orifices all are clean and unobstructed.Main looks like new.
I put it all back together and then tested the compression. around 63 PSI with fairly weak pulls. both the same. Seems solid.
Turned over the engine with gas line off outlet of fuel pump. Pumping sporadically like it should according to posts. took it apart anyways and inspected everything. Looks good. Made sure that it was together right. Retested. alls good
connected gas.
Should work, right??
Pumped the bulb until hard. Choked and with 1 pull started but was sputtering.
After about 15 seconds. It stopped completely and wouldnt restart after many tries. spark is still good.
Even tried a little Quick start. wouldnt run.
Help!!! I have about 20 hours into this thing which is in great condition.
I dont know what to do next?
Im considering taking it apart further and checking the reed valves, but thats a lot of work. Before i do. can I get some ideas of what to look for?
Thanks
Mike.
Honorary Supreme Mariner
Did you replace the coils ?----Were the coils cracked ?----" spark is excellent " means nothing to me.---------Does spark jump a gap of 5/16"on both leads , yes or no ?
Was the magneto plate off the engine when you cut 1/4" off the wires and re-installed in the coils ?
MikMac
Yes magneto plate was off. Cut 1/4" off spark plug wire at the coil.and reconnected to the post on the coil.good connection.
Cam ring is on right. Reads... Top.Facing up
Lots of spark, but i havent used a spark meter.
Any comments on the Reed Valves?
MikMac
sorry. Coils were not cracked. Looked almost new. Tested with Ohm meter . looked good. Maybe ill get a spark tester??
Sorry-----You need to answer questions, even though they seem silly to you.----Does spark jump a gap of 5/16" , yes or no ?----Reed valves are very reliable unless mice built a nest in there.----I was repairng these motors when they were new !------Have a bunch stashed away for parts / rebuild as well.
MikMac
Sorry. Was gone for an hour. Bought a spark tester. It shows good spark. I didnt do a 5/16" test. Can you advise how to do this. Can i just gap the plug that far and ground it.
Right now spark says good on spark tester. but its not 5/!6"
MikMac
Any chance someone could tell me what kind of make shift spark detector i could conjure up to jump a 5/16" gap? I bought an inline spark tester which shows good spark. But want to make sure .
Also. I have been reading many posts about timing. am I correct to assume that if I have both sets of points gapped at .020" at the proper cam spot. That is the timing so to speak. I dont have a timing light or one of those special jigs thats goes on the tapered shaft
But that timing fixture is nothing but a " dummy flywheel "------Thus you can use your flywheel to do the same thing.------It takes a little longer but is the very same concept !
scout-j-m
Yeah, those inline spark testers are almost useless. Yes, they show that you don't have a grounded stop circuit or something that is totally limiting spark but they don't tell you much at all on the quality of it which is often the issue.
They have the adjustable ones you need at most any auto parts store and range from $5 to $10.
Tape 2 pieces of wire to a stick with a 5/16" gap between them.---Put one wire in the plug boot and the end of other wire to the motor block.---Spin the flywheel and see what happens.
MikMac
Got it working. runs great. thanks for all the help.
As it turns out i had 2 problems. 1. The spark plug wire from 1 coil was corroded. Once i fixed that and had good spark. I cleaned the carb. Apparently not good enough. I R&R the carb again this morning. Made sure everything was spotless and used carb cleaner and blew out all orifices.
Put back together and purrs like a kitten. Thanks for all your help. going to paint the cover and she will be like new.
Thanks.
Mike
Crosbyman
I am currently working on a 9.5 and one plug booth was measuring 20 meg !!! to the coil high voltage winding
pulled out he mag plate and plug wire.
​ cut 1/4 inch... no go still 20 meg while the other bottom coil was at 7 Kohms from the plug booth
turns out the small spike in the bad plug socket was heavily corroded
​this new to me 9.5 may turn out to be a dud... found a 1/8 crack in the lower housing just between the two posts facing the powerhead :eek:
​stuffed it with JBD Steel weld putty ...not much else I can do with a cracked body
​this one is a dirty engine .. one which came with a propeller protector almost like it had an industrial life
