1971 johnson 40 horse. Charging system
bg175
Charging system peaking at 12.7 volts at high rpm. Need help testing generator and regulator. Thanks in advance
Honorary Supreme Mariner
That belt driven generator may need a procedure referred to as -----" Polarizing the generator / voltage regulator "------Ever heard of that ?
Good luck performing this procedure on your motor then.
bg175
You sir, are special. There are alot smarter people without vfc the smartass included.
