1971 Evinrude Lower Unit Removal
x-man
I am trying to replace the impeller on this 1971 25 HP outboard. The lower unit drops about an inch is all when the five bolts are removed. Am I missing something? I searched the old threads here, but couldn't find anything on this vintage and HP rating. Thanks in advance for any help.
Honorary Supreme Mariner
On the side of the exhaust housing is a wee cover.----Remove the cover.----Then REMOVE one of the screws on the connecter for the shift rod.
Sometimes it's best to stick a little piece of paper towel or rag into the socket driver when removing one of the hexhead screw from the shift rod coupler.
The socket (or the screw) can get away from you pretty easily. There isn't much room to get a socket in there through the gap.
Once you free up that coupler, the lower unit should drop right out. Might have to jiggle the flywheel just a bit to get 'er to drop free if it's been on there a long time.
x-man
I got it off, thanks. One more issue that may or may not be related. I put everything back together just fine, but now(and maybe it was before) the shift lever is "off" from the detents. When I put the lever in the neutral the lower unit will vibrate itself into forward. I have to put the lever between neutral and reverse to get the lower unit back in neutral. Any Ideas?
Also, the motor will not idle long enough for me to adjust the idle mixture. New ignition, plugs, wires, flywheel, and I took apart and cleaned the carb. Any ideas? This was Grampa's old boat, been in storage for 30 years. My dad claims it never did idle well. Any "tricks of the trade"?
Did you line up the notch on the shift rod with the hole in the connector.---That must be done before the bolt is put in.---And a 1971 model 25 will idle quite well if in good condition.
Seems like the little knob on the gear shift of the lower unit isn't entirely seated into the groove on the shift rod itself?
The setscrew has to be right up in the center of that notch to ensure your shift rod (and gear shifter) are in the proper location.
Maybe crank down the idle speed screw to keep your outboard running at higher RPMS during idle? Might bide you some time to set the mixture scew?
x-man
Yes, it is lined up. I don't believe the bolt would go back in if the notch is not lined up, would it? Or would it?
There is an adjustment at the shift lever at the top.----Note-----Make sure you have things assembled correctly.---Mistakes can be costly.----Have you priced a new forward gear and clutch dog lately ??
Sure. It will tighten up enough for the shift mechanism to work. It just won't work the way it's supposed to, and will behave the way you described.
Sometimes if you move the gear shift lever to extend the knob all the way up, it will help to seat the conenctor into the proper location.
Did it shift normally prior to dropping the lower unit?
x-man
I am not sure. I would have to assume it did, but it has not been used in 30 years, and was sitting in the corner of a shed before I started to refurbish it.
