I got it off, thanks. One more issue that may or may not be related. I put everything back together just fine, but now(and maybe it was before) the shift lever is "off" from the detents. When I put the lever in the neutral the lower unit will vibrate itself into forward. I have to put the lever between neutral and reverse to get the lower unit back in neutral. Any Ideas?
Also, the motor will not idle long enough for me to adjust the idle mixture. New ignition, plugs, wires, flywheel, and I took apart and cleaned the carb. Any ideas? This was Grampa's old boat, been in storage for 30 years. My dad claims it never did idle well. Any "tricks of the trade"?
