I got the motor little while back it was fireing very weak on both cyls put in points and condensors and got hot fire on both plugs. it busted off but I didnt run it as it wasnt in drum. put it in a drum today and it runs off the top cyl only, took out plugs and tested fire again hot on both and the cyls are cycling ok what could cause the lower cyl to be dead?? drawing a blank here, thanks guys
