River_Lizard
- Jan 17, 2012
- 378
I've got a thread going in the restore section but I thought I'd better throw this in the Evinrude section to see if I could find some knowledge from members here.
1971 85 hp Evinrude. Is not pumping water from the seller's report on eBay. My first need is to remove the lower unit and inspect the pump housing, impeller (replace it) and make sure the PO who installed the lower unit (not original) installed it correctly. Which brings up my question: I've replaced impellers on newer OB's but have never been around an electric shift style, what should I expect when pulling it? Any special requirements to drop the unit? I'm planning on purchasing a service manual, which brand is the best to purchase?
Is there wires going down to the lower unit?
Also, I couldn't find a complete 71 pump kit, only an impeller replacement, do they make a full kit for that year any more?
Thanks for any input you can provide. I'd like to get the lower unit done in the next couple of weeks so I can test the pump and then do a float test of the whole boat to make sure it shifts correctly and runs under load.
