1971 4hp mercury outboard
rckt3
I hope im in the right section, I have a 4hp merc, it was shifting from neutral to forward and back without any problem as I was fixing the recoil I switch from neutral to forward (not sure why i did that) the engine not running, and now I cant get it to go back into neutral. any thoughts on whats going on with it.?
motor has to be turning over to shift
dont try to shift a non-running motor
Turn throttle grip to lowest setting and see if it will shift.
rckt3
thx racerone, I pulled the prop and prop shaft out and the shifter moved back to position, reinstalled the prop shaft and prop, turned the motor one complete rotation by hand and all is well. thx for the input guys.
