1971 25hp run J4J Champion? Or ....
davidmbv
Hello, forgive me for asking a question that I’m sure this has gotten some discussion in the past. It seems like my web searches have turned up a variety of different opinions. Well, I’m hoping to get some advice from folks that have had real life experience running a similar motor than mine. I have a 71 Johnson 25hp and am curious what you people suggest I run for plugs. I replaced the ignition parts with Sierra coils, condensers and plugs. I had it tuned up over the winter before I started learning to tinker with it myself. At that time, the “mechanic” replaced the plugs with Champion j8C’s, changed the impeller and gear oil.
I recently read the service manual that states my motor calls for Champion J4J’s. I found them for sale online from OMC. Should I keep running the J8C’s or would the J4J’s run better. I have an electric trolling motor I use when trolling for trout and Bass angling. I plan to run the Johnson 25hp at WOT or close, to get to point A to B. I also plan to throw a smaller high speed jet in when trout fishing lakes above 6k feet to 7500’ elevation(local shops near those lakes have me advise on what size jet)
I’ll replace the smaller jet with the stock one when I’m back to my local lower lakes.
The motor was running great using the J8s when it was working. I have been working out some unrelated issues due to coil wires breaking due to bad wire placement and about to replace the upper crankshaft seal to fix a leaking seal I noticed when going through the magneto components. Looking forward to setting the timing once that’s done with my new timing tool.
thanks in advance for any suggestions on what plugs I should run.
Dave
davidmbv
Oops. I meant to write I found J4C’s for sale. I was considering ordering those in place if the J8C’s I’ve been running. I guess J4J’s have been discontinued. The service am manual calls for J4J’s.
thanks
Vic.S
Recommended plugs are now J4C gapped at 0.030"
Grade 8 are far too hot
F_R
Honorary Supreme Mariner
That 25 is a souped up motor running at high rpm. I'd say those j8c plugs could get hot enough to cause pre-ignition and burn pistons. It might not happen but why chance it?
Use the ---J4C------Make sure thermostat is working properly.
oldboat1
^^agree. should be tuned to run well on J4Cs. If J8s seem like a solution, likely have some ignition or carb work remaining.
davidmbv
Great thanks. I’ll throw in a set of J4C’s and tune it up.
