LindenLongRods
- Jul 10, 2007
- 192
I see where the white one goes , how do I get old one out? I can't see if old is even in there though and I put cap back alreadydeleted
The white piece is the needle valve bearing.my carb kit comes with 3 little black o rings, and a white plastic piece, do I need them or where do they go? I realize the kit is universalView attachment 339330
I carefully threaded a long wood screw into the old one and pulled it out Do not damage the casting if you try.The white piece is the needle valve bearing.
You're the best, got it using screw. Now just put new one in first before actual jet screw correct? I know stupid question also black O-Rings obsolete or don't need?I carefully threaded a long wood screw into the old one and pulled it out Do not damage the casting if you try.
I used the needle to seat the new one. I do not know if that is the way it is done but it worked for me.You're the best, got it using screw. Now just put new one in first before actual jet screw correct? I know stupid question
Black o-rings? don't need?I used the needle to seat the new one. I do not know if that is the way it is done but it worked for me.
I am not sure what they are. Maybe for a different carb? I always seem to have extra pieces when doing carbs.Black o-rings? don't need?
What kit did you buy?my carb kit comes with 3 little black o rings, and a white plastic piece, do I need them or where do they go? I realize the kit is universalView attachment 339330
384413, it also came with plastic float, I stayed with the cork one it moved more freelyWhat kit did you buy?
