1970 Johnson 115 hp electric shift lower unit torque specs
allen waters
hey Guys, I have a 1970 Johnson 115 hp outboard, any one have the torque specs on the propeller bearing housing bolts?
Thanks
Honorary Supreme Mariner
80 to100 inch-lbs will do it.---Test the gearcase on the bench before installing it !!
allen waters
OK my Johnson model # 115ESL70D - when I torqued to 80 inch pounds the little o-rings #307853 for the four bolts on the propeller bearing housing, peeled off a little sliver of rubber on each one of the o-rings? are we sure about the 80-100 inch-lbs torque?
also I plan on installing new seals into the drive shaft thrust bearing housing, can you tell me what sealer I should use on the outside of the seals, and what lube on the rubber part of the seals? I read about special 3 way grease and special sealer that were both factory product, is there a good lube and sealant I can purchase from my local auto parts store I can use or that you recommend?
Well-----I am sure of the tork value.---Are you sure that you have the correct o-rings !!!
allen waters
Thanks for the reply racerone, and boobie, I have ordered new o rings and will re torque. the o rings I used were part of a kit from a local marine dealer, and did not have the actual part number shown. just a kit number. but new ones on the way:joyous:
