1970 Evinrude 25hp just purchased!! I have problems...
dono16
This is a new engine to me, it fired up , idles runs good, BUT where does this motor spit out the cooling water???? the only place i see it comming out is out the transom.....theres like 2 holes right behind where the impeller housing would be ,,' its spitting the water toward the back of the boat" thats the only place the water is coming out , it is a strait solid stream like it could be correct, but ive never seen displacement of water there on any otboard ive ever owned and im concerned , im guessingthe impeller is bad, but i dont see ant other place where the water would diplace. there is a dichare half way up the transom "on the side if u wre looking at the back of the motor or boat...... that is spitting water and air ""Very Very little water""", im guessing exhaust,???? but i thought exhaust comes out underwater above the prop???? Need help & need to know what im dealing with.... Thanks guys!!
Ohh modle # 25002E
D
DJ
Guest
Re: 1970 Evinrude 25hp just purchased!! I have problems...
You should have a hole on the back of the leg (midsection-facing rearward) that is called an exhaust relief. Water and some exhaust will exit there. It will not be a steady stream. Your engine does not have a telltale like most modern engines do.
While it is running, feel the upper cylinder head with your fingers. Caution: it will be warm but it should not burn you in three seconds. It's going to be about 125 to 140 degrees.
Since the engine is new to you, I would replace the impeller anyway. They're availble here on iboats.
dono16
So by back of the leg,, do you mean where i think the exhaust is comming out,,, like BACK like if iwas looking at the back of the boat on the trailer ,,prop facing me ,,,,if this is correct am i fine and thats how its suppose to be ,,,,,THANKS
dono16
So im kinda confused ,,,,,, wher does it spit the water,, is that where , if you say i should replace the impeller ,, wheres the water come out,?????? sorry i need a lil more explination....thanks
HighTrim
dono I believe you have some of your terminology mixed up. The transom is the rear wall of the boat. DJ gave excellent advice, I would listen to it. Good luck.
D
DJ
Guest
Yes, there is an outlet, on the leg, between the cavitation plate and the bottom of the powerhead. That is the exhaust relief.
I still would replace the impeller. Check the head while running.
jbjennings
This motor is a little older than yours, but your's should do the same as far as water out the exhaust....
Hope this helps, and you have a really fine motor....one I'd like to have!
Good luck,
JBJ
HighTrim
This will show some of the other terminology
"http://images.google.ca/imgres?imgurl=http://www.ccg-gcc.gc.ca/sar/nsm-msn/images/pi_chap_5a_e.gif&imgrefurl=http://www.ccg-gcc.gc.ca/sar/nsm-msn/ichapter_05_e.htm&h=518&w=267&sz=16&hl=en&start=40&tbnid=eT75To-PkH6egM:&tbnh=131&tbnw=68&prev=/images%3Fq%3Dboat%2Btransom%2Bport%2Bstern%2Bstarboard%26start%3D20%26gbv%3D2%26ndsp%3D20%26svnum%3D10%26hl%3Den%26safe%3Dstrict%26client%3Ddell-row%26channel%3Dca%26sa%3DN%26ad%3Dw5"
dono16
Ok guys i dont have or know your terminology,,,, so tell me strait am i fine ,,, i know to relpace the impeller,,, ive been through my share of outboards to know and know how to replace it,, , So I would like a straits answer Y or N on my engine if everything sounds ok ,,is this a odd system ,,or air cooled ?? should it be sptting water somewhere or not?????if so where???that i dont know about,,, ,, Im just going by the rule my dad rold me " if the engines not spitting water ,,shut it down cuz your gonna ruin it..... """" I just want to know and do the right thing ,, id hate to ruin this engine.
Thanks again
dono16
JBjennings,,,,,,,thanks ,,,, for your help, and descriptions,,,your right very simmilar,,however i dont have nearly that amount of water comming out,,, so............ new impeller and ill be good right?????????? thanks
jbjennings
Sounds like that's your problem, need a new impeller. On such a fine engine, I would be very careful to look at my water pump housing as well and to tell you the truth, I might consider buying a whole new water pump kit (housing and all) to be sure if I saw ANY sign of wear on the steel inserts in the top and bottom of the housing. Check that--I'd just get a whole new housing and all and not worry about it. If your fins are broken off your impeller when you check it, try to be very careful to locate all the broken pieces. Don't be too disappointed if it doesn't run well at the lake, like Samott told me once---they all run good in a barrel. That motor can be tuned up to run like new most likely if it isn't right now and pretty darned cheaply, too. GREAT motor!!!
JBJ
samo_ott
JBJ had it right. There should be water coming out of it like in his photos. Also, did you touch the head when it was running? It should be warm but not hot to the touch. Water should not sizzle when splashed on it.
I'd replace the pump or impeller and then test again. That's a nice engine I'd like to have one also!
whywhyzed
Banned
The spray at a fast idle on your 25 should look like this:
attachment.php
D
DJ
Guest
whywhyzed,
I like your engine stand. It looks heavy duty and multi purpose.;):)
samo_ott
No kidding, what the heck is that bolted to?
dono16
First off... thank you to all of you,,,,,, I really appreciate it... i just ordered a new impeller, also when i ran the motor it was very brief, 10 to 20 sec. ............only 2 times. ... .. Ive replaced an impeller on my 73 johnson, 9.5hp and my 70 Chrysler 35 hp they were almost the same instal , is there anything different i would need to know about for this motor????? according to ya''llll it sounds like i just got a dandy motor,,,,,I love to hear that!!!!!!!!!!!is it kind--of a rare motor ???? or just bad-***,,,anyway I love these oldies there simple motors and fun... thanks again fellas!!!!!
Silvertip
Honorary Supreme Mariner
YES -- Your engine is behaving normally. The exhaust relief ports allow a small amount of water and exhaust to exit the engine above the water line at idle because of the exhaust back pressure when motionless. At speed, the water and exhaust exit through the prop. The only thing different about your engine is it does not have the tell-tale stream newer engines have. If you see a fine mist of water from the relief ports the engine is fine. The recommendation to change the water pump impeller is for preventive reasons. Anytime you buy a used engine it is a good idea to replace the impeller since you have no idea when it was done last.
samo_ott
Actually, I don't believe the 1970 exits through the prop, that came in later years.
samo_ott
I bet everyone has one of those for their test stands! If not they surely need one!
