1970 Evinrude 25 hp
Cochranbr94
Ok. Been having the same issue for quite a while. The motor will run fine at idle and runs fine to about 30% above idle. Anything above it sounds like it's bogging down then dies. Things I've done so far are cleaned carburetor (12 times now), checked slow speed adjustment for damage and adjusted it to proper spec, adjusted timing, changed fuel pump, new fuel lines, new plugs, new impeller, changed fuel out in the tank, checked float level, new ignition coils, and latest was buying gasket sealant and sealing any air leaks between the upper part of the carb and lower. The same issue has remained after all this. Also, everything was done to the service manual instructions. Thanks for any help.
jimmbo
Compression test? Have you tried a different fuel tank? Primer bulb correctly installed? Is the timing advancing as the throttle is opened? Points gapped @ 0.020"? Is it firing on both cylinders? Drop test results?
Cochranbr94
Jiimbo- compression test has been done. Sorry I failed to mention that. Both were at 100 or 105 I believe. Fuel tank is 1 year old as well as fuel line from tank to motor. Points gapped correctly. Both cylinders firing. Not sure how to check timing advancement on throttle adjustment
Lindy46- Correct. Haven't removed it because I don't have the special tool but I cleaned it thoroughly. And ran a small piece of wire in it to ensure nothing stuck in there.
