Cochranbr94
Thread starter- Joined
- Sep 5, 2017
- 2
Ok. Been having the same issue for quite a while. The motor will run fine at idle and runs fine to about 30% above idle. Anything above it sounds like it's bogging down then dies. Things I've done so far are cleaned carburetor (12 times now), checked slow speed adjustment for damage and adjusted it to proper spec, adjusted timing, changed fuel pump, new fuel lines, new plugs, new impeller, changed fuel out in the tank, checked float level, new ignition coils, and latest was buying gasket sealant and sealing any air leaks between the upper part of the carb and lower. The same issue has remained after all this. Also, everything was done to the service manual instructions. Thanks for any help.
