frustratedboater
Thread starter- Joined
- Jul 10, 2007
- 505
I have a 1970 Evinrude 18hp outboard bogging down issue going to open throttle. I have double checked the high speed fuel circuit and still having simular issue. I have reset the points to a snug 20 thousanths and same issue.
The engine sounds a little clunky when at idle and not real smooth, however will run at real low idle. If I throttle up all the way at 3/4 rev it will settle back down as if to stall. Is this a timing issue? I do not have a timing tool bar) like I've seen online but I've worked on a ton of these and always set the points like discussed and others ran like a dream. I'm stuck..
