FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Is the screw over the choke an idling or high speed adjustment? Also in gear and throttled up something seems to slip. Does this motor have a slip prop?
Hi Don<br />The screw to which you refer is the low speed air/fuel mix. The high speed is fixed. There is a rubber hub in the propeller on your model. It is designed to break loose in the event something is hit. Yours may be bad. You will have to test it. I don't mean to pry, but if you could elaborare a little more on your exact problem or problems we could be more help.
Alcan,<br /><br />Thanks for the info on the carburator. The prop seems to slip at running speeds. It works fine at idle speeds. Can I remove the prop and see if something is worn?<br /><br />Thanks <br /><br />Don
