1970 85 hp evinrude sucking gas
ifitwasus
I have a 1970 85hp Evinrude that I have been trying to get running correctly. I have rebuilt the carbs, impeller and put on new head gaskets. Its got a good spark and good compression. It runs really good, but it seems like it is using a excessive amount of fuel. The pick up tube in the tank broke and the fuel line was collapsed on the inside, so I bought regular automotive fuel line and just stuck it down in the tank where the pick up tube was. Could this be making it use more fuel? Like I said it runs really good. The people here have been a great help with other issues and hopefully can help with this. Thank you in advance.
Bob_VT
Re: 1970 85 hp evinrude sucking gas
8.5 gallons per hour at wide open throttle maybe more, maybe less depending on boat load and weather conditions. SO..... a 6 gallon tank can be gone in under one hour. Yes, the V-4 motors can be thirsty if you are heavy on the throttle....... that's the reason to find the sweet spot when cruising.
