jbing81
Thread starter- Joined
- May 22, 2010
- 421
Hey guys I need some advice on purchasing a'69 Merc 350. I've searched all over the net the past week and haven't found a whole lot on these older motors. I went this afternoon to see the motor run. The owner had it in a tank when I arrived, the motor started well, shifted as it should, went through its rpm's without hesitation, and pumped water very well. The owner stated that he has replaced one coil, both condensors, two points, the water pump, the gear oil, and a carb rebuild. everything looks to be tip top, however without a lot of reference material online I'm kind of hesitant to lay down $500 on this motor. If there's anyone out there who can lend some insight is greatly appreciate it.
